TwinTurbo.NET: Nissan 300ZX forum - PS: When doing this test have a shut off valve in >>`
ZUL8TR
on November 21, 2014 at 2:30 AM
Air pressure test the injectors on the fuel rail B4 >>>
posted by ZUL8TR
on November 17, 2014 at 06:32 AM
the loop at the air pump to prevent backflow past the air compressor rings once the fuel rail loop is pressured up. Otherwise the gage pressure drop will be misleading.
ZUL8TR in Orlando,FL
Injector Replacement Help
Z32CheekiBreeki
14:27:09 11/13/14
The plastic caps on the old injectors?
-Grimm-
15:00:50 11/13/14
Should have addressed more in that post
-Grimm-
15:02:37 11/13/14
ZUL8TR
06:32:25 11/17/14
When redoing the connectors to the new style >>>
ZUL8TR
06:37:14 11/17/14
would pressurizing the rail with fuel be just as good??? (n/m)
LivinTheDream
06:40:57 11/20/14
No.The leak test is before the install on the engine >>
ZUL8TR
02:23:55 11/21/14
I mean hooking up the fuel lines before installing the rail?
LivinTheDream
12:49:31 11/21/14
PS: When doing this test have a shut off valve in >>` -
ZUL8TR
02:30:01 11/21/14
they should be fine if no mechanical damage seen
itsa300zx
16:04:54 11/13/14
Yeah no damage as far as I can tell
Z32CheekiBreeki
16:47:32 11/13/14
if you don't have access to a sonic cleaner, I would just
itsa300zx
17:12:53 11/13/14
the injectors im trying to get out and re use are new style
Z32CheekiBreeki
17:46:48 11/13/14
Carb cleaner would be fine
-Grimm-
18:10:20 11/13/14
Nearly impossible to get them out without damaging the caps
ZXoltan
16:30:43 11/14/14
Re: Injector Replacement Help
Kvert
17:27:19 11/14/14
Re: Re: Injector Replacement Help
Kvert
17:37:52 11/14/14
Excellent
Z32CheekiBreeki
08:21:28 11/15/14
Forgot to mention
Z32CheekiBreeki
08:25:07 11/15/14
Re: Forgot to mention
Kvert
22:52:15 11/15/14
